Results 1 to 10 of 18
Thread: Caddy Engine Transplant
    Nov 2007
    After some info here .......
    Currently investigating the possibility of transplanting the drivetrain of a MK5 GTI manual into a Caddy. I believe the Caddy's used the MK5 chassis as a "donor" vehicle and many components are interchangeable.
    Therefore in Jeremy Clarkson's infamous words .... "How hard can it be?"
    Any ideas, suggestions etc ..... ? Idea on costs and time?
    Intending a full transplant of engine & all electrics etc from a donor GTI to a high mileage MY08 1.6 manual Caddy Life .....
    And then obviously tune the daylights out of it at the end .....
    Turns out I still need a 7 seater but not a Multivan size car and the engines in a manual in the Caddy's just don't do it for me so this idea was born.
    Adelaide hills, SA
    It should be relatively easy when you have both cars in the garage.
    Time wise.... take 1 week off work.
    Aug 2013
    Interesting.
    Jun 2011
    sydney
    should go for r32 engine instead
    Nov 2007
    Quote Originally Posted by psyone View Post
    too much work involved in that and ultimately too slow for the $$$$
    2.0TFSI is good for 240+kw with a K04 which will be plenty for a Caddy i think
    Jan 2014
    Sutherland Shire, Sydney, NSW
    Man, this would be an ultimate sleeper. Good luck if you decide to go ahead with the project.
    06 9n3 Polo GTI
    Nov 2007
    Found an inspirational thread over in the UK. CR engine but still the concept looks OK.
    http://vwcaddy.net/forums/lofiversio....php?t455.html
    So, a few more questions ....
    Anybody know what a 05-08 Mk5 5 GTI stat writeoff is worth? There is an 08 at pickles at the moment but that may be to dear?
    Also, it appears that the cluster out of the MK5 will fit, questions is, how about the whole dash?
    Jun 2011
    sydney
    dont think golf dash fits the caddy. the cluster, i think it will fit but you wont be able to use the 2 buttons on it (to set time and what not) but if you got mfsw it wont matter. the only problem you'll have is codding another cluster to your caddy. for models before 2007 its easy, after that vw changed the immobiliser. i have a 2008 model and bought a touran high line cluster from germany, still cant code it in.
    i have spoken to smartuki on another forum, caddy2k.com lots of caddy info there and its very active. he told me that gti engine and transmission is a very easy swap and it just bolt in, no mods required. i was thinkin of doing the same to my caddy. 1.6l petrol is way too weak for a work van. i need to change my rear brakes so i'll be going to camden gti shop and gonna talk to them about this conversion and the $$$$ involved.
    Nov 2007
    If it happens I'm going to use all the electronics from the GTI including the immobiliser. Essentially the car will think its a GTI except it will be in a Caddy body.......
    Jun 2011
    sydney
    ah true true. just gut the gti and fit it all into the caddy! would be interesting to know whats a wrecked gti would cost tho. probably at least 5k ?
