Results 1 to 3 of 3
Thread: Fuse Layout MY12 Caddy
    I hate how VW don't include a fuse layout for your car.
    Does anybody have a fuse layout for a MY12 Caddy Maxi Life?
    2012 Caddy Maxi Life
    2011 Multivan
    2008 Skoda Scout (Gone.......L)
    2008 Caddy 1st 25 fuse postions
    Closest I could find was a 2008. Hope it helps someone.
    Position of fuses in fuse holder C, from May 2008
    No. Current Flow Diagram designation Nominal value Function/component Terminal
    1 - SC1 - Fuse 1 on fuse holder C - - - Vacant -
    2 - SC2 - Fuse 2 on fuse holder C - - - Vacant -
    3 - SC3 - Fuse 3 on fuse holder C - - - Vacant -
    4 - SC4 - Fuse 4 on fuse holder C - - - Vacant -
    5 - SC5-Fuse 5 on fuse holder C - - - Vacant -
    6 - SC6 - Fuse 6 on fuse holder C - - - Vacant -
    7 - SC7 - Fuse 7 on fuse holder C - - - Vacant -
    8 - SC8 - Fuse 8 on fuse holder C - - - Vacant -
    9 - SC9 - Fuse 9 on fuse holder C 10 A -
    T4g - 4-pin connector, black, coupling station for video fuse ¹)
    T10c - 10-pin connector, electric interface⁴)
    15
    10 - SC10 - Fuse 10 on fuse holder C 5 A -
    J17 - Fuel pump relay²)
    J533 - Data bus diagnostic interface
    J623 - Engine control unit
    15
    11 - SC11 - Fuse 11 on fuse holder C 5 A - J446 - Parking aid control unit³) 15
    12 - SC12 - Fuse 12 on fuse holder C 10 A -
    G41 - Taximeter¹)
    G511 - Mirror taxi meter¹)
    T2ac - 2-pin connector, for flashlight charging station, police²)
    T28a - 28-pin connector²)
    15
    13 - SC13 - Fuse 13 on fuse holder C 5 A -
    E102 - Headlight range control regulator
    E132 - Traction control system switch
    E256 - TCS and ESP button³)
    E313 - Selector lever⁴)
    F - Brake light switch
    J104 - ABS control unit
    J111 - Brake light relay⁷)
    J345 - Trailer detector control unit⁵)
    J500 - Power steering control unit⁶)
    J587 - Selector lever sensors control unit⁴)
    J743 - Mechatronics for direct shift gearbox⁴)
    V48 - Left headlight range control motor
    V49 - Right headlight range control motor
    15
    14 - SC14 - Fuse 14 on fuse holder C 5 A -
    F4 - Reversing light switch⁷)
    G70 - Air mass meter²),³)
    J485 - Auxiliary heater operation relay⁶)
    N79 - Heater element for crankcase breather¹),²),⁴)
    N80 - Activated charcoal filter system solenoid valve 1⁴)
    T16 - 16-pin connector, on left under dash panel, self-diagnosis connection
    15
    15 - SC15 - Fuse 15 on fuse holder C 5 A -
    J234 - Airbag control unit
    K145 - Front passenger side airbag deactivated warning lamp⁵)
    15
    16 - SC16 - Fuse 16 on fuse holder C 5 A -
    E16 - Heater/heat output switch⁷)
    G65 - High-pressure sender⁶)
    G226 - Oil level and oil temperature sender⁵)
    J255 - Climatronic control unit⁶)
    J285 - Control unit in dash panel insert
    J359 - Low heat output relay⁸)
    J360 - High heat output relay⁸)
    Y - Automatic anti-dazzle interior mirror
    15
    17 - SC17 - Fuse 17 on fuse holder C 7,5 A -
    F216 - Rear fog light cut-out switch²)
    M41 - Left tail light and rear fog light bulb³)
    RFL
    18 - SC18 - Fuse 18 on fuse holder C 5 A -
    J601 - Taxi alarm remote control, control unit¹)
    T10c - Electric interface⁴)
    30
    19 - SC19 - Fuse 19 on fuse holder C 10 A -
    G41 - Taximeter¹)
    R8 - Two-way radio¹)
    30
    20 - SC20 - Fuse 20 on fuse holder C 10 A - T10c - Electric interface⁴) 30
    21 - SC21 - Fuse 21 on fuse holder C 10 A -
    E1 - Lighting switch
    E313 - Selector lever¹)
    F189 - Tiptronic switch¹)
    G397 - Rain and light detector sensor⁶)
    J217 - Automatic gearbox control unit²)
    J255 - Climatronic control unit⁵)
    J301 - Air conditioning system control unit⁵)
    J587 - Selector lever sensors control unit¹)
    R149 - Remote control receiver for auxiliary coolant heater, behind centre dash panel³)
    30
    22 - SC22 - Fuse 22 on fuse holder C 10 A -
    J386 - Driver door control unit⁸)
    J387 - Front passenger door control unit⁸)
    30
    23 - SC23 - Fuse 23 on fuse holder C 10 A - T3r - Connector front speed camera⁷) 30
    24 - SC24 - Fuse 24 on fuse holder C 5 A -
    G273 - Interior monitoring sensor⁶)
    G384 - Vehicle inclination sender⁶)
    H12 - Alarm horn⁶),⁷)
    30
    25 - SC25 - Fuse 25 on fuse holder C - - - Vacant -
    2011 Multivan
    2008 Caddy remaining fuse positions
    26 - SC26 - Fuse 26 on fuse holder C 10 A - T2ab - Connector on charging station for flashlight³) 15
    27 - SC27 - Fuse 27 on fuse holder C 20 A - J246 - Cut-out relay for air conditioning system magnetic coupling⁵) 15
    28 - SC28 - Fuse 28 on fuse holder C 5 A - E1 - Light switch²) 75X
    28 - SC28 - Fuse 28 on fuse holder C 20 A - E18 - Rear fog light switch¹) 75X
    29 - SC29 - Fuse 29 on fuse holder C 15 A - V12 - Rear window wiper motor⁴) 75X
    30 - SC30 - Fuse 30 on fuse holder C 25 A - E1 - Light switch¹) 75X
    31 - SC31 - Fuse 31 on fuse holder C 5 A -
    E16 - Heater/heat output switch⁴)
    Z20 - Left washer jet heater element
    Z21 - Right washer jet heater element
    75X
    32 - SC32 - Fuse 32 on fuse holder C 15 A - V59 - Windscreen and rear window washer pump 75X
    33 - SC33-Fuse 33 on fuse holder C 40 A -
    J485 - Auxiliary heater operation relay²)
    75X
    34 - SC34 - Fuse 34 on fuse holder C - - - Vacant -
    35 - SC35 - Fuse 35 on fuse holder C 10 A -
    W41 - Fluorescent light right¹)
    W42 - Fluorescent light left¹)
    30
    36 - SC36 - Fuse 36 on fuse holder C - - - Vacant -
    37 - SC37 - Fuse 37 on fuse holder C 15 A - M31 - Right headlight dipped beam bulb³) 56B
    38 - SC38 - Fuse 38 on fuse holder C 15 A - M29 - Left headlight dipped beam bulb²) 56B
    39 - SC39 - Fuse 39 on fuse holder C 20 A - J345 - Trailer coupling control unit¹) 30
    40 - SC40 - Fuse 40 on fuse holder C 20 A - J345 - Trailer coupling control unit¹) 30
    41 - SC41 - Fuse 41 on fuse holder C 20 A - J345 - Trailer coupling control unit¹) 30
    42 - SC42 - Fuse 42 on fuse holder C 15 A - U5 - Front 12 V socket 30
    42 - SC42 - Fuse 42 on fuse holder C 30A -
    U18 - 12 V socket 2, on left in luggage compartment
    30
    43 - SC43 - Fuse 43 on fuse holder C 15 A -
    J17 - Fuel pump relay⁵),⁶)
    J49 - Electric fuel pump 2 relay⁶)
    30
    44 - SC44 - Fuse 44 on fuse holder C 40 A - J126 - Fresh air blower control unit⁴) -
    45 - SC45 - Fuse 45 on fuse holder C 20 A -
    J39 - Headlight washer system relay³)
    V11 - Headlight washer system pump³)
    30
    46 - SC46 - Fuse 46 on fuse holder C 7,5 A - J519-Onboard power supply control unit 30
    47 - SC47 - Fuse 47 on fuse holder C 25 A - U1-Cigarette lighter 30
    48 - SC48 - Fuse 48 on fuse holder C 30 A - J774 - Heated front seats control unit¹) 30
    49 - SC49 - Fuse 49 on fuse holder C 10 A - J386 - Driver door control unit²)
    J387 - Front passenger door control unit²)
    30
    50 - SC50 - Fuse 50 on fuse holder C 25 A - J393 - Convenience system central control unit 30
    51 - SC51 - Fuse 51 on fuse holder C 30 A - T10ai - Connector coupling point special signals³) 30
    52 - SC52 - Fuse 52 on fuse holder C 25 A - J13 - Fresh air blower relay²)
    Z1 - Heated rear window
    30
    53 - SC53 - Fuse 53 on fuse holder C - - - Vacant -
    54 - SC54 - Fuse 54 on fuse holder C - - - Vacant -
    55 - SC55 - Fuse 55 on fuse holder C - - - Vacant -
    56 - SC56 - Fuse 56 on fuse holder C - - - Vacant -
    57 - SC57-Fuse 57 on fuse holder C 5 A - J754 - Accident data memory³)
    58d
    58 - SC58 - Fuse 58 on fuse holder C 10 A - T4g - Video fuse³) 30
    30
    2011 Multivan
