Results 1 to 10 of 14
Thread: Diff flip
    Apr 2014
    Diff flip
    Hi all,
    I am pretty keen to lower my caddy but because I have the newer tsi and don't have a leaf pack I can't just get the pack reset. The kits you buy with the diff flip seem to be the only option. It is illegal in qld isn't it ? Is there any safety issues ?
    Jan 2012
    Regarding legality, I thought any modification for aesthetics in qld was illegal. I'm down in vic myself though the rear end of my air bag setup came from qld with the axle requiring the flip in order to have the clearance to hold the airbag.
    melbourne
    Anyone found an Aussie seller for the diff flip kit?
    Jan 2012
    Maybe, PM me
    Apr 2014
    Darkside has a kit for this application. Any one used it ?
    Apr 2014
    Fmflex, does the caddy still feel solid with your flip ?
    Jan 2012
    Solid in what way?
    Mine's bagged all round so may not be a fair comparison. But to compare to my previous setup of pedders mk5 golf lowered front struts and springs and the rear leaf spring reset it rides heaps nicer. Mine's a trade vehicle so carries a fair amount of weight.
    So mk5 golf front struts same as mk3 2005 caddy?
    Jan 2012
    Yes they're interchangable
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Scottygreg View Post
    Hi all,
    On the legality, you have to make sure that you have a minimum ground clearance at any point under the vehicle after the change. Also, you have to have a minimum bump stop clearance. There is also clearance to bodywork that has to be considered. Lastly, you have to make sure that the front and rear are lowered the same amount, otherwise this changes the castor angle and this can affect high speed steering stability.
