yea caddy2k is the best when it comes to finding info for your caddy.
Superior; your've made a few friends over there too....... well done
any progress on air suspension ?
Air bags are in!
Still have some modifications to make to get it lower, rear leaf springs need to be reset so we can get it lower and i need to notch the front, at the moment the front tyre sits about 15mm in the guard but the guard lip is sitting hard on the tyre so i'll probably have to run 225's as i dont want to roll the guards. Here are some quick pics i took on my phone, will post up more of the setup later.
VW Caddy MY15 TDI- Ravenna Blue
Current Mods - Forge Wheels - 19x9" | AccuAir E-Level Air Suspension | Throttle Controller
Full Colour Coded & Gloss Black Grills
nice, looks awesome. now you need some big brakes to fill these voids in the wheels ! i got all my components for r32 brakes conversion. just need to get someone to swap them over.
Thanks,
Between center hub and guard it sits at 310mm Rear and 290mm Front, once i make up new airbag mounts on the rear it will sit at 290mm all round, undecided if i will notch the front since it will all be level and pretty low anyway.
Where did you get your brakes from? Were they easy to find? How much did they cost?
looks so good.. the only thing that bugs me about caddy is the different mirrors.. why couldnt they just have 2 big ones..
Yep looks so weird from the front, i don't get the point of it. Inside the car visually there is no difference in vision, the drivers side has a blind spot curve but the passenger side doesn't, don't know why they just didn't put the blind spot curve mirror on the passenger side.
Wouldn't mind putting some Golf mirror on it.
