Looks very nice. Any interior mods yet? Btw where are you getting your air ride installed at and how much if you dont mind me asking?
Hey!
Picked up a new Caddy (MY15) TDI in Ravenna Blue a few months back with the full colour coded option, have since done the following -
Gloss Black Front Grilles
Custom Forge Wheels - 19x9"
Bilstein Coilovers & Super Low Axle Flip Kit
Throttle Response Controller
Crescendo Component Speakers
Hertz Amp
(Hertz Sub to be installed).
The front coilovers didn't go as low as i had hoped, and i'm having troubles with the rear end as the weight i carry varies 300kg and it either sits too high for my liking or it sits on bumpstops (which are already cut down). Inner guards have also been modified to fit the wheels.
Full AccuAir E-Level Air Suspension kit is being installed in 2 weeks!![]()
The vehicle is used as Paint Correction & Paint Protection mobile unit so the inside has been fully fitted out with custom ply line (carpeted), Motextion Bulkhead, Custom 300L Water Tank, hidden Pressure Washer, 12v Water Pump (with garden hose), Silent Generator etc etc...
Airbags will most likely be the last mod for now (except a tune), will look at fitting a Golf R front end, and maybe custom R style rear bar down the track.
VW Caddy MY15 TDI- Ravenna Blue
Current Mods - Forge Wheels - 19x9" | AccuAir E-Level Air Suspension | Throttle Controller
Full Colour Coded & Gloss Black Grills
Looks great mate. Im looking for a caddy too and will be looking at darkside for some gear...VDUB.
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Whats the airbag set up cost you and does it require engineering?
Thanks!
No interior mods yet, did think about changing the seats but to be honest i dont know if i can be bothered as the seat rail height is different to the hatch backs.
The kit i am getting is an AccuAir E-Level Kit with Touchpad Controller from Home Page - I am driving up to QLD to get it installed by the distributor (i know him personally so will help install it).
I bought the bags and lines second hand from a guy that had them in a Caddy and i bought all the components (ECU/Fuses/Controller/Tank/Compressor etc.) brand new, basically what you see in this - AccuAir e-Level System with Touchpad Controller - Featured Products
Yeah i'll have to get it engineered, the bags and brackets i'm buying second hand have been engineered previously so there should be no problems with it passing.
If you bought it all brand new you would be looking at around $5200 + $2500 installation i believe.
yea you basically just need to get touran seat bases and then you can fit any vag seats similar to golf mk5+ release
i got mine from germany fairly cheap, postage was more than the actual item. from memory it was around $250 or so. it was my 1st mod as these caddy seats were terrible
btw how much are you asking for bilsteins ?
Thanks for the tip! I did see some nice Scirocco R seats on Ebay for sale a month ago, i was tempted!
I dont mind the seats in it, not sure if the MY15 is different to the previous ones as it also has Bluetooth and Cruise control, i dont think the previous models have that included standard? I remember when i looked at the ones VW had on display when i ordered mine 8 months ago the seats were different to the ones i have.
Go have a squizz at Caddy2k.com - Home of the VW caddy MK3 2k & Maxi owners club forum
Pommie forum for passionate Caddy owners, wont see a lot when first join but get your comments up and the oyster opens...
If your thinking about Touran seats check VW wreckers in New Zealand..... should be cheaper freight than Germany.
