Results 1 to 6 of 6
Thread: Considering a 2009 Maxi
    Nov 2017
    Fremantle, WA
    G’day Caddy group,
    I’m going to purchase a Caddy and am looking at options here in Perth/Freo. I’ve seen a 2009 Maxi and want to know if its possible to install the rear bench seat in this van, after I remove the cargo barrier and plan to relocate it behind the seat.
    I’ve been sent some details that it’s a 75kw SG5 2KH AC2. Any guidance as to this vehicle?
    Thanks in advance.
    Nov 2015
    Nice choice. To be able to fit the VW OEM 3rd row bench seat the vehicle will need to have the seat attachment rails on the floor. The seat slides onto them and locks in place over the lugs. You can see the grey rails that run front to back in this picture.
    http://vw-caddy.yolasite.com/resourc...nterior_03.jpg
    The vehicle will also need to have the retractable seat belts which you can also see in the picture.
    I believe that all the facelifted 2010+ Caddy Maxi Life came with the 3rd row bench seat as standard, not sure about the pre-facelife Caddy Maxi Life.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Nov 2017
    Fremantle, WA
    Quote Originally Posted by feenix74 View Post
    Thanks for the feedback. The picture is really helpful. I've found a seat at a wreckers nearby so we're looking good in that respect. Do you know how tightly the bolts should be torqued to the floor?
    Cheers.
    Nov 2015
    No idea how much torque for the bolts to secure the rails to the floor.
    Nov 2017
    Fremantle, WA
    OK, thanks I'll keep digging.
    Nov 2015
    You could try a VW dealer's service/spare parts department. I believe the latest Caddy 4 (well 3.5 because it is really just another facelift) uses the same system for the rear 3rd row bench seat. The service/spare parts department should have instruction on how to install them because they are still an optional extra for the base model SWB Caddy Life.
