Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Caddy TDI inlet clean
    Jun 2006
    Orange NSW
    Thumbs up Caddy TDI inlet clean
    Hey guys.
    I did the inlet flush that Andrew has been raving on about to me for a couple of months now..
    Definitely worth it if your Caddy has done over 50k. Mine's done 65 and the difference it made was impressive.
    It's smoother on trailing throttle (very light throttle), more responsive and pulls harder too. It also seems to come on boost more smoothly. I'm pretty happy with the result.
    Here's what i did.
    I pulled the pressure side intercooler hose off and sprayed the stuff in with the engine idling. This worked OK but if i wasn't careful it dribbled back out.
    I ended up slipping the hose back over, jamming the nozzle under it and into the inlet. Then i grabbed a rag and sealed it off so it couldn't blow back out. Squirting it in, in increments as the engine didn't really like it too much and idled pretty rough if you squirted it in too fast (i actually caused it to stall at one point!).
    All in all i'd definitely recommend it. Go see your mechanic if you don't like doing these things yourself and ask them about it. Not sure what it's worth as the old man have a couple of boxes full of the stuff he got from a retiring Wynns rep.
    cleaning my inlet manifold has been crossing my mind a bit of late with my car just ticking over 80k today.
    Where do you get that stuff?
    So basically you squirt it down the guts of the inlet to the manifold?
    Jun 2006
    Orange NSW
    Quote Originally Posted by GoLfMan View Post
    Most automotive shops should sell it. And yes, it's pretty much that simple. You just need a compressor for the vacuum generator as i couldn't find a vacuum line to hook it into.
    Jan 2008
    Sunshine Coast
    Anyone with a DPF should be wary of doing this just quietly, but a must do for any non DPF'ers!!
    Apr 2006
    Hobart,Tas
    I actually use the Wynns high pressure 3 direct into the throttle body. This stuff is designed for all late deisels, especially the DBF types.
    I do it on each desel VW that comes into my workshop and the surprise on my customers faces is great!
    This kit comes with a thin tube with 3 very fine holes which sprays out into the maniflod, the idea is to try and clean at the actual valve arrangment on the late model vehicles.
    Takes all of 5 minutes to do,
    Glad you have found a difference Preeny doing the clean using the early type cleaner. My clean gave my Caddy made about 50% difference to the power that the Oettinger reflash did!
    Cheers, Andrew
    melbourne
    i've been thinking of doing this for a while now too.....
    i've already done the intercooler clean, made a slight difference, i felt, getting all that crap out.
    but as for the manifold clean, have i got the right idea:
    air intake/ filter -> turbo charge -> intercooler -> intake manifold -> engine.....?
    if that's right, can i simply remove the post-intercooler pipe, and, with the engine idling, squirt that stuff into the intake manifold?
    is it really that easy?
    Jun 2006
    Orange NSW
    Yes. You are right and it really is that easy.
    Apr 2006
    Hobart,Tas
    Thats the way I do them Scott,
    Unclip the intake pipe out of the throttle body. Spray diectly deep into the manifold. The version I use was developed in Europe and trialled in Tasmania by Wynns last year before the mainland took it on.
    The kits have a pressure can which the hose pushes onto. Like a small pressure can of paint) Comes with a direct injection bottle of fuel treament.
    High Pressure 3 is the name.
    Cheers!
    Aug 2007
    Agreed x 2
    Alba European
    melbourne
    cheers guys!
    i am SO checking this out tomorrow
