Now, in this thread I mentioned I used silicone sealant to mount the light. When VW Australia got wind of it, I was accused of spreading information designed to make these lights crack and was used as a basis for refusing to provide one under warranty.
Well, I can say that after 18 months, I have gone through 2 winters with freezing temperatures at times, and I have only had one crack up top in the vicinity of the lip. This is not an issue as the piece is attached to the silicone bead and it does not allow any water in. Nothing more and it does not need replacing, so it clearly IS the method of mounting that puts stress on the lens and causes it to crack.
I am seriously thinking of buying one more, paying a 3D scanning outfit to scan one for me and then get them to print one out using a much more flexible, translucent plastic and then sharing that around.
See, it's not some phantom driver in a ute with scaffolding planks causing it as VW Australia claimed!
