Results 1 to 5 of 5
Thread: Brake Rotor Size
    Jul 2007
    Brissy
    Brake Rotor Size
    Hi Caddy folks
    My sister has asked me to do the front brakes and some other maintenance on her Caddy.
    I just cannot work out what size rotors to buy.
    Listings show 3 sizes along with option codes
    280MM 1ZM, 1ZF
    288MM 1ZE
    312MM 1LJ, 1ZA
    The only option code related to brakes is: 1AC - Anti-lock brake system (ABS)
    Which does not help much.
    VIN: WV2ZZZ 2K Z 7X076748
    TYPE: 2KB D43
    NIV: Caddy-Kombi Life 77KW TDI AG6
    ENGINE CODE: BLS
    TRANS CODE: JPH
    So what should I be getting ?
    I'm not likely to have access to the car until the day she brings it around for fitment.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mornington Peninsula, VIC
    Are you going by the PR-code sheet from the first page of the service book?
    Erwin will give you a full list of options, but that will cost 7 euro.
    Maybe just call the dealer with the VIN and get the part number from them?
    Sent from my SM-N960F using Tapatalk
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    In an instance like this where there are 3x possible disk sizes and you dont have access to the car to measure beforehand, I would just buy all 3x sizes so you know for sure you will have the right parts on the day, and then return the 2x incorrect ones. I think this is less inconvenient than having to get the car back on another day due to having incorrect parts.
    Obviously if you decide to do this just make sure wherever you buy them from has a good return policy and keep your receipt.
    1K0 615 301 T disc 288x25
    3C0 698 151 J pads
    Pulled from partslink off the VIN number
    Jul 2007
    Brissy
    Thanks Gav.
    I finally got through to VW parts today, after many unanswered phone calls.
    Asking on the internet is almost faster than the dealer network
    VW stated 1ZE 288x25mm
    MK4 GTI - Sold
