Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: AirConditioning Recycle Button Turns Off
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by johnnie5 View Post
    go for a drive through the M5 tunnel and see if you still think there is a difference between recirc and fresh
    Yep.
    Even with a carbon activated pollen filter, it still gets fumy on 'fresh'.
    FYI, the Caddy uses the same pollen filter as MK5/6 Golf, Jetta, B6-onwards Passat, and Tiguan. Also fits Octavia and Superb.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2011
    Sydney NSW
    I have no doubt as it is akin to following a diesel belching smoke, and yes, I have been through the M5 tunnel and it is bad. A pollen filter will not do too much, and any freshener just means you are breathing in scented pollution.
    When I was talking about traffic, I was talking about surface traffic.
    On the M5 tunnel, it should have better ventilation. If a workplace were to provide such an environment for its workers, it would be closed down.
    I have read the manual already. There is nothing about recirculation being turned off.
    I should have mentioned it is an intermittent problem.
    @wai Maybe it is time dependent.
    If so this is a terrible feature. I've been driving for 20 years & never had to be saved from CO2 levels.
    Quote Originally Posted by wai View Post
    yes and even with surface traffic you get pollution pumped into the car since car exhausts are low to the ground at the rear of the car
    give me old school closed recirc vent anyday
    May 2014
    Sutherland Shire
    Have you got the AC on full cold..?
    I find that if the temp is set all the way to COLD, it then sets itself to re-circulate..
    Anything warmer and you have to manually turn it on every time you get in
    Quote Originally Posted by nicholas787 View Post
    It's been winter so rarely on full cold.
    It usually stays on so I don't think to check it every time. I only notice it's off when I breathe in the dirty exhaust of a vehicle in front.
    May 2014
    Sutherland Shire
    Quote Originally Posted by skywalka View Post
    Thanks for that… It's winter for me too.
    Erskineville, NSW
    I think the difference is that one user has AC on & the other has it off???
    when i had my 07 caddy it was either on full cold or full hot
    it didnt change the fact that it always went back to fresh air
