Brand new in January.......... under warrenty.... VW dealer problem not yours, get your boss to start jumping. Dealers can sometimes look for easy way out, dont let them.
Hi guys,
I'm a courier & drive a brand new Caddy my company received in January.
Every day I'll jump back in my car, drive back into traffic & breathe in a lung full of bus fumes etc. This occurs because the A/C Recycle button has disabled itself. This drives me crazy because by then turning it back on, & trapping the fumes in the vehicle, would make things worse.
What is going on here?
Thanks.
Do you mean recycle or recirculation
If you read the manual it will probably tell you it turns off automatically so as you don't leave it on and go to sleep when the CO2 level rises and kills you.
Its a safety feature.
Wouldn't the cabin filter do the job of sorting out the bus fumes, etc?
I'm not sure about the Caddy but the Octavia / Golf filters come in two types Pollen & Pollution. Maybe they have 2 options for the Caddy (or the Golf units fit)
Pollen Filter (1K0819644B)
Pollution Filter (1K2819653B)
Interesting as the Climate Control on my Caddy Maxi Life will only switch back to fresh air in after a certain amount of time after the ignition has been switched off. I can go an collect newspapers and be away for say 10 minutes, but when I get back in, it is still on recirculation. I haven't worked out how long it has to be off before it switches back to fresh air in.
As for traffic fumes, unless there is something belching out smote that is being sucked into your Caddy, there is little difference in the air quality for fresh:recirc. Even filters are not going to do very much, and if they do, they will block quickly.
Real men dont need instruction manuals
