Results 1 to 3 of 3
Thread: Vw Amarok 2012 oil pressure issue
    Mar 2024
    Afternoon everyone,
    After abit of advice if anyone can help.
    Got a 2012 Amarok that’s had the oil pressure light keep coming on, I’ve had the switch, filter and a new oil pump put in but just got a back from the mechanic and the light is still coming on, it seems to be running absolutely fine but I’ve no idea why I’m still getting the light?
    Jun 2020
    QLD
    You need a good quality scanner and see what the fault codes are. Otherwise you are are just playing spare parts lottery.
    I think Supercheap will scan it for a fee, also Racq can scan it for you.
    I would think the next logical step would be to check the oil pickup. What engine does your car have? If yours is the petrol 4 cylinder then the oil pickup is reasonably common to get blocked with debris (as well as silicon/sealant if the car has been worked on in the past). You will have ot drain your freshly replaced oil, but capture it in a bottle and you can reuse it.
    Another think to check, once again if you have the petrol 4 cylinder engine, is the cam bridge. There is a filter screen in the cam bridge which is well known to fall out/fall apart/get blocked and then it starves the camshafts of oil pressure. I had a friend with a Golf GTI have the cam bridge fail with no warning and it ruined his engine - cost him about $11k to get a replacement engine sourced and fitted.
