Originally Posted by
V6 Rok
Thanks for the replies.
Having driven cars with permanently locked diffs, I know the diff lock is not engaged. Unplugging the actuator cable would most likely show a fault code.
Not having owned an AWD car before it may well be a characteristic of AWD, but I highly doubt that is the whole problem as the scenario that creates the wet road understeer in so insignificant that those same conditions, on the very same roads with previous utes, have never created cause for concern at such slow speeds coasting into an intersection with very little throttle. If it does turn out to just be how it is I'll be very disappointed as the even with all the tech in the Amarok it's nowhere near as safe on a wet road as any ute I've owned in the last 30 years ! The fact that it handles excellent for it's size in dry conditions points me to the tyres as the main culprit.
I notice the 18 inch wheels seem to come with the Continetal Cross Contact or Michelin Primacy tyres. The Conti's have a tread wear rating of 680 which is considerably higher than other LT/AT tyres I've used before indicating a hard/long lasting compound. Can any owners with the Michelin's have a look at the tread wear number for those ?
I've owned a few cars and motorbikes that came with Conti's as original fitment and I've always preferred what ever I've replaced them with. VW recommends 29/29 without a load and I'm at 30/30 as I rarely carry any weight so can't move the load around. I'll experiment with tyre pressures a bit more next and post up results - if/when it rains again any time soon !
