Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: V6 Amarok Handling on Wet Roads
  1. #31
    Jan 2019
    Not sure if this helps, but there is some mention of understeer with the 4motion during a track test
    Volkswagen Amarok Nurburgring review - Autoblog
  2. #32
    Adelaide hills, SA
    A bit different, theirs didn’t understeer at very slow speed and they actually enjoyed it.
  3. #33
    Jan 2019
    Ok here's a review at slower speeds talking about cornering - no mention of tyres though.
    I'm really interested to know if other V6 owners have noticed understeer in the wet etc as I'm considering the purchase of a new vehicle and the permanent 4wd system being safer is one of the selling points over say a Ranger.
    I currently drive a manual Amarok 2.0L and on very wet roundabouts if the wheels lose traction then I do notice slight understeer, but thats actually slipping tyres, not just normal driving with no loss of traction.
    The major downside of throwing all the good gear at the flagship Amarok is a significant increase in weight"
    "The extra bulk also blunts on-road dynamics, particularly in tighter corners where the front end tends to bog down and understeer and body roll are easily provoked. It’s not a deal breaker, but it does make the 2.0-litre Amarok with its less potent but 80kg lighter 125kW/440Nm engine less of a handful in the twisty stuff. Where the V6 Amarok feels most comfortable is on flowing country roads, when the new speed-sensitive Servotronic steering firms up nicely and offers decent feel."
    Full reveiw text here https://www.carsales.com.au/editorial/details/volkswagen-amarok-2016-review-102730/
  4. #34
    Erskineville, NSW
    I'd love to see what the alignment is set at.
    I'm not familiar with the Amarok suspension. Does anyone know how adjustable it is?
  5. #35
    Feb 2019
    Gold Coast, QLD
    Hi,
    I’ve got a 2018 V6 Highline and it handles superb in the wet.
    No weight in the tray, 2 inch lift, arb bar with winch up front.
    Tyres are pirelli scorpion on 18’s from the factory.
    I came from a 2010 sr5 hilux that had cooper st’s and it was like being on ice in the wet.
    I can push the rok though the roundabouts in the wet hard and haven’t noticed any understeer.
    I’d check your wheel alignment, failing that it must be the rubber (they might be old rubber and have gone hard??)
    The centre diff is non locking Torsen style diff and the rear as other have said is open unless manually locked...
    Hope this helps...
    Cheers,
    Josh
  6. #36
    Adelaide hills, SA
    The feedback I’m getting from customers who drive V6 Amarok is, that it holds well and can really be pushed into the corners. From looking at the V6 engine bay, you will notice that the engine has lower centre of gravity than 2.0L engine, and being heavier it pushes the front wheels down preventing loss of traction better than 2.0L Amarok, which is around for longer time and there aren’t any complaints that it would have worst handling than its opposition.
  7. #37
    Feb 2019
    Quote Originally Posted by doinitsideways View Post
    Hi,
    Cheers,
    Josh
    Which Scorpions have you got Josh ?
    I'm a fan of the now discontinued ATR's
    Quote Originally Posted by wetaline2 View Post
    Interesting article. The other night I had a decent drive of a 4cyl Amarok (dry weather only) and while it's got smaller wheels and different tyres I'd tend to agree with some of that. I'm yet to drive any car that benefits from more weight over the front wheels at slow speeds.
    I'll be checking alignment next week but think a change of tyres to something with a lower treadwear number and higher traction rating will help - I've not seen any B traction rated tyres for a while.
  8. #38
    Feb 2019
    Gold Coast, QLD
    Hi Rok,
    They were the factory supplied tyre. It is the Scorpion ATR 255/60R18 112T
    Like I said, have been fantastic on the road including in the numerous roundabouts in the wet that used to see my hilux with massive understeer. I remember shifting into 4 high just to navigate them which alleviated it a little, but still had understeer.
    I just want something a bit bigger now, they look out of place now with the lift kit... just look that bit too small. And functionality wise, they don’t ballon enough when let down when I go to Fraser Island.
  9. #39
    Dec 2010
    Helensburgh
    +1
    Heavier engines cause change of direction to be lazier and slower, you can't defy physics. Audis suffered for years with this problem because they persisted with putting engines right out front and as they got bigger the problems got worse.
  10. #40
    Adelaide hills, SA
    Quote Originally Posted by Ozsko View Post
    Why don’t you take both Amaroks for test drive and then talk physics?
