Results 11 to 20 of 24
Thread: Tsi300 misfire
    Sep 2011
    hunter valley
    If no other codes then it's a good chance its just carbon buildup causing your issues.
    Did valve clean this morning Still misfiring after it they did have buildup though
    Have codes
    cylinder 3 misfire
    Hide cylinder
    Random/multiple misfire detected
    Fuel too low (fuel light is on)
    Thinking of getting my hands on a compression tester
    2007 polo gti
    1995 golf mk3 8v
    Sep 2011
    hunter valley
    Epc light on and engine light flashes when it wants
    2007 polo gti
    1995 golf mk3 8v
    Sep 2011
    hunter valley
    Quote Originally Posted by ziggy_jacob View Post
    I didn't end up getting the injectors checked really wish I did after I get a compression check done next thing to do
    I do remember some family telling me the car smelled of petrol after shutting it off and restarting it
    Possible having a injector stuck open with out codes relating to it?
    2007 polo gti
    1995 golf mk3 8v
    Sep 2011
    hunter valley
    Sad news peeps after carrying out compression test have concluded cylinder 3 has lost compression
    Cyl #4-200
    Cyl #3-25
    Cyl #2-197.5
    Cyl #1-195
    2007 polo gti
    1995 golf mk3 8v
    Nov 2007
    Ideal oppertunity to do a rebuild. MK6 GTI internals (rods and pistons) will fit, and easily available from ECS Tuning in OEM or upgraded components.
    This is what I will eventually do to my TSI300 (sorry TSI480)
    May 2020
    JOHANNESBURG
    Cyl #4-200
    Cyl #3-25
    Cyl #2-197.5
    Cyl #1-195
    Sad news mate, this was my greatest fear and so good to drive the TSI underrated Utes. oftern look if i can spot my TSI as it used to misfire like urs no fault codes and engine light came come. Dammit man but rebuild her stronger than ever.
    @ Sharkie, Yes still using the fuel of satan the TDI been Mapped and downpipe. next is egr delete
    Sep 2011
    hunter valley
    Send links and I may consider it haha
    2007 polo gti
    1995 golf mk3 8v
    Nov 2007
    Lots of choices (and not the only supplier for these parts)
    Rods - I would go forged and not simply a replacement
    403 Forbidden
    Pistons - again go forged and make it Stg 3 proof
    403 Forbidden
    The above should all be perfectly doable in the TSI, but bear in mind that not everything is interchangeable. I recently discovered that the sumps (including all internals such as baffles and oil pickup) are not the same between the Mk6 GTI and the TSI300 Amarok. The TSI300 is much larger to almost 1.5ls of extra oil capacity.
    Nov 2007
    A 2nd hand TSI300 engine (with its own history and possible problems), will probably set you back $2-3K. You can get quality parts for less than that and then its just labour costs (free if you have skills and time).
    Sep 2011
    hunter valley
    I'm contemplating mk7 R motor do you know of any complications
