I have a 2012 Amarok that has some sort of fault with the indicator lamp on the centre console for the transfer case. The light is stuck showing the ute is in 4wd high on startup, but when you toggle the switch between high and low range the dash lights up and 4wd engages and disengages as per normal. Has anyone had this happen to them before and if so, what is the solution for the problem? Cheers.
