Hi All,
I recently bought a used 2011 Amarok with engine code CDCA and 145,000km on the clock. After a bit of research I wanted to check that it had the newer lower timing belt cover installed. It didn't so I went about replacing the old one this weekend.
Replacement went well but I did notice that the timing belt, which should have about ~30k km on it if the service record is to be believed, was possibly not at the correct tension. The tensioner indictor arrow is to the left of the marks you use when tensioning a new belt (see below).
My question is, is it supposed to be like that after use or should I be applying some more tension to the belt?
Thanks
https://imgur.com/a/R70MZkP
Thanks Transporter. So assuming it stays in the same position when at tdc, do we think it needs re-tensioning (if done properly) or is it safe to leave it alone?
Thanks
Just turn the camshaft to TDC and see what the tensioner is doing. It’s automatic tensioner and can move a bit.
I’d check that when everything is off.
Thanks Transporter,
I did happen to check again last night and the engine had stopped more or less right on bottom dead center. I observed that the tensioner was much closer at this point but still not quite in between the markers. The engine was still slightly warm though, so not sure if this would give me a false reading.
Will try again when its cool and rotate to TDC.
