Suspension recommendation
I have a 2017 Amarok 2.0 4x2 that’s making some noise in (maybe) suspension when there’s load in the cabin and tray. I’ve had 3 different comments on what the problem is. Paddlers say I need new suspension, my usual workshop Wolfsburg says nothings wrong and suspension workshop down the road says nothing wrong but some bushes could need replacing.
Noise is normally when turning a bend when lots of load in the vehicle, not at high speed. Like a creaking sound and a general thud. It was given to me with some big all terrain wheels/tyres on it.
Anybody have any suggestions what it could be?
I was going to sell it as I don’t need the large vehicle anymore but seeing that I don’t owe any money on it might just keep it and try and make some time to get out of town in it. I would like to maybe upgrade the suspension so that I get a better on road feel for it. I don’t go off road more than a dirt track. Anybody have some suggestions on some suspension replacement that doesn’t cost that much?
TIA
Most suspension will be geared towards off road for these cars. Granted I have a lift, but the bilsteins I have are pretty good. I think the noises you suggest are bush related. You could probably just leave the rear leaves, replace shocks and front struts to be a bit more economical but maybe check the push option too.
These bushes are generally pretty good quality
SuperPro Suspension Parts and Poly Bushings forVW AMAROK 2010-on - 4motion
Thanks. Will go back to Heasmans and get the bushes done and look at options you mentioned.
- You may not post replies
- You may not edit your posts
Forum Rules
