Results 1 to 4 of 4
Thread: Spare tyre winch repair.
    Feb 2021
    Australind, WA
    Hi Guys,
    I am trying to fix the spare tyre winch on my step sons Amarok.
    The original problem was a bunched up wire rope and jamming....
    I pulled it down and replaced the wire rope......
    Now is the tricky part....I did take some snaps as I opened it up, but did sort of explode when I opened it.
    I got it all back together except a have a Pawl left over.....lol
    I assume THAT rachets the cable drum and stops it unravelling, but can't see how it works.
    Does anyone know where this fits in the picture?
    My first thought was that it was located by the 5mm pin in the opening, but the hole in the pawl is only 4mm.
    There is a 4mm hole midway on the cable drum, but there isn't a pin to locate it? ( Is the pin mssing?)
    I would have thought there would be a spring in there some where as well.....?
    Anyone gone through this?
    Shared album - Stephen Robinson - Google Photos
    Steve
    Feb 2021
    Australind, WA
    I found where I was going wrong.
    I found the pin that locates the pawl in the cable drum and I had taken a pic that showed the tip of the pawl.
    It's all back together and working.
    Sent from my SM-G970F using Tapatalk
    Sep 2022
    Baldivis, WA
    Hi Steve,
    I have a similar problem. Did you drill out the 'rivets' from the factory to split the housing?
    Craig
    Sep 2020
    Booragoon, WA
    Anyone having issues with the spare tyre winch mine was replaced under recall notice, 2022 V6 Aventura
