I'm just back from IBC (in Amsterdam) and spotted this in the carpark whilst I as there.
Clearly it's an SNG (Satellite News Gathering) fitout, aftermarket wheels and a lift kit.
Nice mod on the tail light for cable entry.
Stabilising jacks on the rear to keep the rig steady and the dish aligned.
Overall height with the dish down was 2.85M !
Probably a bunch of other stuff in there, enjoy!
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
7? MK1 Caddy
12 Amarok
Here's an article on the conversion.
XRacer speeds up DSNG - ibc-content | Europe's Broadcast Industry News & Analysis | TVBEurope
The new XRacer DSNG system from ND SatCom allows live video uplinks on the move, at speeds of up to 120kph, and has a more-conventional raised dish for static set ups.
The satellite antenna comes with a Comms On The Move phase-array antenna from Raysat, which can transmit at up to 4mbps. This is hidden under a dome on the back of the main Skyray Compact antenna, and “means you can transmit all the time while you are driving,” which is ideal for truly fast-moving stories, explained Michael Hirschle, system engineer for mobile stations. It uses ND SatCom’s own SkyWAN modem, which is fully meshed, so users can transmit directly from one uplink to the other, without going back to a hub first.
The VW Amarok-based unit also comes with built-in editing station and redundant power systems.
The main antenna system uses automatic pointing and all system parameters can be up and running at the push of a button. An ND SatCom App allows the crew to operate the XRacer via smart phone.
Using ND SatCom’s Media Fleet Manager, the vehicle’s transmission capabilities can be remotely controlled from the network hub station, to let the crew concentrate on getting the story. The Media Fleet Manager is an easy-to-use management tool to plan, schedule and book DVB and IP uplink sessions via fixed and mobile stations. – David Fox
7? MK1 Caddy
12 Amarok
Holy crap that thing has had some work done to it!
Look awesome though.
That fitout would be worth much more than the car itself.
7? MK1 Caddy
12 Amarok
Cool
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
