Page 28 of 28 FirstFirst ... 18262728
Results 271 to 274 of 274
Thread: Sharkie's TSI Amarok Build
  1. #271
    Nov 2007
    So the 2wd Amarok is 4wd now?
    Not quite, almost there. Just a progress update
    Front bits are now done ... new aluminium sump, front diff (serviced too) and FR and FL driveshafts in. Sump clearance was probably the most complicated issue so far.
    All electrics from the donor is ready to go in with all required control units plus entire gearbox/transfer case/rear diff loom. Next major mechanical items are transfer case and rear driveshafts.
  2. #272
    Nov 2007
    Major progress milestone achieved ...
    TDI gearbox (used) on the way into Big Red
    Sharkie's TSI Amarok Build-tdi-gearbox-way-into-tsi-jpg
    TDI gearbox and transfer case (and propshaft) fitted
    Sharkie's TSI Amarok Build-tsi-tdi-gearbox-transfer-case-propshaft-1-jpg
    Sharkie's TSI Amarok Build-tsi-tdi-gearbox-transfer-case-propshaft-2-jpg
    Big Red is now driveable again as the TDI box does not have a 3rd gear synchro issue (still in 2WD but with all 4WD hardware fitted). Next up is the electronics.
  3. #273
    Jun 2020
    QLD
    Coming along nicely lukas
  4. #274
    May 2020
    JOHANNESBURG
    Looking good Yster,
    Maybe I should do a V6 swop like in brazil LOL in the single cab.
    but welldone on work.
