Page 10 of 28 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 274
Thread: Sharkie's TSI Amarok Build
  1. #91
    Nov 2007
    Was the Scirocco seriously down on Power?
    I would have though a stage 2+ Roc would have been 200+kWaw given that it is running a K04.
    I'd be interested to see the rest of the results to put the numbers into context.
    Not many cars on the day to compare with I'm afraid, only 3 x 2.0Ts, Amarok, Scirrocco R and Mk6 GTI Stg 3 (275HP) And you're correct, I was expecting more from the Rocco as well. Don't believe the GTI owner was too happy either.
    4 more FWDs ... Mk3s and a Mk1 Cabrio (none of which cracked 100HP) so the numbers had very little reference to each other.
    The rest was aircooled much older VWs .....
  2. #92
    Nov 2007
    Just as a reference, from testing during tuning, we already know that the Stg1 Amarok makes more power than a MK6 GTI Stg2 .....
    Stg 2 on the Amarok to be an exhaust and possibly an intake, though the stock intake is pretty good and will be hard to beat. Some scope for improvement in the exhaust but not much, possibly ~5kw ....
    The stock intercooler on the Amarok is massive with a different end tank design than any of the other 2.0Ts from VAG so we don't believe it will be possible to improve on it, even with Stg 3.
    Stg 3 (K04) is expected so deliver good results (~+50kw) so look out for that in the future .....
  3. #93
    That's a bit of a pity. What turbo was the Stg 3 GTI? I would have expected the Roc to be around that power level....
    There's another dyo event being held with more watercooled cars: Dyno Day Saturday 28th June
    I know they're looking for a couple more cars to make the numbers to run the event
    Nov 2007
    Yeah, .... no. I don't have a lot of faith in rolling road dyno's. Have a number (sort of now), and will be sticking to the hub dyno from now on, where tyre pressures, wheel weights, strap down and cooling don't have an impact.
    Considering the GTI will likely be running at that event again, I'll just take the figures and apply a correction factor to the Rok to see where it would have been on that dyno .....
  5. #95
    Adelaide hills, SA
    Great result Sharkie!
  6. #96
    Canberra
    Any idea when the tune's will be available?
    Also interested in seeing what economy on cruise (if you can control your right foot now,lol) you get?
    I have had a play around with the air intake behind the grill on mine and about to delete the centre muffler and had thoughts about cutting the cat out and replacing with a 100 or 200 cell high flow and get the cell rectified when the tune is available to us plebs.
    Any ideas on what the difference is between the amarok tsi300 turbo and the golf gti turbo is?
    Sorry many questions, but no one seems to be playing with the TSI300 amarok.
  7. #97
    Nov 2007
    Quote Originally Posted by Helmet View Post
    Don't worry, all the playing with the TSI300 Amarok (Or should I say TSI450 ) happens right here ....
    Tune should be out in a few weeks time. Still doing some testing including road testing now, APR will release full figures and details when they are ready.
    TSI300 Amarok's engine probably most closely related to Audi Q5 2.0T's with the turbo very similar but not exactly the same. Golf GTI and Amarok runs 2 different turbos and the Amarok runs a different exhaust cam to the GTI. K04 upgrade appears to be straight forward and easy to do and will be "tested" in due course .....
    The Amarok's stock intake is very good (as in high flowing) and we have tested a few configs on that so far. Other than aesthetics, not much to be gained by changing unless you go beyond Stg2.
    The exhaust due to the layout of the engine (longitudinal) is also pretty good, gains to be had though by going larger 3" v 2.5" and replacing the stock cat with a high flow cat. Due to anticipated low demand for this piece of hardware unlikely to be offered by any of the tuners, sho will have to be a custom job for those that want it done.
  8. #98
    Nov 2007
    Also, fuel economy largely appears to be unaffected ..... did a 200km run yesterday (Brisbane => Sunny Coast => Brisbane with a bit of running around at the coast). Fuel economy at a fairly liberal interpretation of the speed limit still at 8.8l/100km overall.
    In town using the extra power also seems to be consistent at ~12l/100km.
  9. #99
    Jan 2006
    Do your wheels really weigh 40kg Sharkie? I look very fwd to catching up with you finally and doing some comparisons..
  10. #100
    Erskineville, NSW
    Quote Originally Posted by bombsquad21 View Post
    Do your wheels really weigh 40kg Sharkie?..
    It wouldn't surprise me. OEM 17x7.5 with road tyres on an Audi A4 will weigh in at 21-25kg depending on the style of the wheel. Every extra inch in diameter will add 1-2kg and every extra inch in width will add 1-2kg. Add in that they are "heavy duty" off road style rims & 40kg isn't outside the realms of possibility. All in the wrong spot too (outside of the cylinder).
    If you can pull some weight out of the wheel tyre combo you'll see some noticeable gains in acceleration & suburban fuel economy.
