Page 27 of 28 FirstFirst ... 1725262728 LastLast
Results 261 to 270 of 274
Thread: Sharkie's TSI Amarok Build
  1. #261
    Apr 2021
    The donor Amarok does have a diff that locks in the rear too, so that will be available eventually. I will use the gear surround switches from the donor as it has everything I need including the switch for the rear diff lock. So, the switch from Big Red and the rear diff from the donor will likely be up at some point.
    Use the diff lock when accelerating hard and it auto disengages at 80km/h (I think). On light offroading such as dirt tracks it worked really well too. Was a worthwhile upgrade I think.
    Thanks mate 👍
    PM me when you decide to sell the diff, i'm in melb but i'm sure we can work something out.
    With the rear diff have you looked into gear ratios? From what i've found our 2wds run 4.3 and the 4x4 run 4.1.
    Sharkie's TSI Amarok Build-screenshot_20240625_091635_drive-jpg
  2. #262
    Jun 2020
    QLD
    Presumably lower diff ratio and therefore lower final ratios on 4x4 are better for crawling up obstacles as oppose to the 2wd would have greater benefit from a higher diff ratio, reducing rpm at higher speeds and improving fuel economy or possibly increasing top speeds.
  3. #263
    Apr 2021
    Yeah but as far as I understand it's the other way round, so the 2wd petrol has the highest gearing and therefore shortest gears.
  4. #264
    Nov 2007
    Quote Originally Posted by EZZA View Post
    Which is why my stock gearbox is going in for an upgrade. It has a broken 3rd gear synchro anyway, so sending it in for a longer 1st and 2nd second plus all round syncho replacement to make them stronger. Have a specialist gearbox place in Brisbane that does custom builds.
    Will be using the donor's gearbox whilst that is being done.
  5. #265
    Apr 2021
    Ah got it, i do remember you writing that now.
    So my issue will be trying to find a factory locked petrol diff with the 4.3 ratio or trying to find an aftermarket e-locking or trutrak center to convert my current diff.
    There's an ARB air locker center for sale at the minute for $600 but I don't want to have to run a compressor to actuate it etc.
  6. #266
    Nov 2007
    The 2WD diesels also ran the same diff as the TSI, might be a few more of those around.
  7. #267
    Nov 2007
    4WD conversion progress
    I will be doing a full build thread on this as somebody may find it useful.
    Some teasers though ...
    Sharkie's TSI Amarok Build-front-diff-sump-jpg
    Sharkie's TSI Amarok Build-front-diff-sump-2-jpg
    Who can tell me what milestone was just reached? LOL
  8. #268
    Jun 2020
    QLD
    I don’t know, as I can never seem to see any of your photos
  9. #269
    Nov 2007
    Quote Originally Posted by lloydus67 View Post
    Definitely not my photos; I'd suggest using a different browser/app if photos are a problem for you.
  10. #270
    So the 2wd Amarok is 4wd now?
