Page 14 of 28 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 274
Thread: Sharkie's TSI Amarok Build
  1. #131
    Jun 2014
    South Africa
    PCV return appears to be the culprit for the flute noise. Its like blowing across a bottle top ..... I have it too. Its not the diverter as I run a GFB modified diverter, yet the sound is still there.
    When the exhaust is built that will eliminate that as a possible culprit (though unlikely to be anyway) and then the K04 turbo should do the trick .....
    With APR's tune we saw 210+kw and 480+NM before de-tuning a bit (to a final 196kw/433NM) for engine safety's sake.
    I've seen reports of 250kw/550NM on a K04 upgrade on the TSI Amarok's out of the UK, so hoping we can achieve that too.
    Yeah APR tune sounds thoroughly tested, those are some insane figures... this tune i have feels like all they adjusted was boost...!! Have a mate who tunes with Dimsport. He is pretty keen to get his hands on the ecu to see what he can do, very respected tuner in SA, really makes sure engine is "Safe" so lets see...
    Thanks for the reply...
  2. #132
    Nov 2007
    TBH anybody who thinks another tune can compare with APR is just kidding themselves or trying to justify their alternative .......
    In this case there was almost a 100 individual dyno runs with tune mods after each and lots of road kms for data logging. Guy (or Mark) can probably confirm but I think there was over 70 files uploaded and over 50man hours spent by APR Aus in developing this tune. They did such a great job and the fruits of their (and the engineers at APR in the USA each night) labour is now starting to be used across the world where TSI Amaroks are being sold.
    The topping on it all is that port tuning is also opened up for further/future changes.
  3. #133
    Nov 2009
    SEQLD
    Hi Sharkie, did your factory bluetooth work fine when you did the rns510 upgrade?
    Will be doing the rns510 upgrade in mine sometime soon.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  4. #134
    Adelaide hills, SA
    It should be,
    it did in mine when I installed the RCD510.
  5. #135
    Nov 2009
    SEQLD
    It should be,
    That's good to hear. Thanks
    MY20 Golf GTI TCR
  6. #136
    Nov 2007
    Yes, no issues with the BT at all. On MY14+ models the RNS needs VCDS coding to integrate with the MFD.
    also a RVC will need coding to work if you decide to add that too. In BNE I can help with that if you need.
  7. #137
    Nov 2009
    SEQLD
    Cheers mate
    MY20 Golf GTI TCR
  8. #138
    Nov 2007
    Grab Handle
    From MY14 onwards many Amarok models lost the drivers side A-pillar grab handle
    After getting a VW parts quote for $300, I started looking around breaker yards ..... and found this for $60 off an Ultimate
    Sharkie's TSI Amarok Build-handle7_zps87054521-jpg
    And after 10mins this afternoon
    Sharkie's TSI Amarok Build-handle2_zpsb074f91d-jpg
    handle installed
  9. #139
    Nov 2009
    SEQLD
    Nice buy. I'll swap ya instrument cluster... miss having a coolant temp gauge.
    MY20 Golf GTI TCR
  10. #140
    Nov 2007
    Fitted OEM 18" Durban alloys, custom powder coated in satin black a while ago.
    Sharkie's TSI Amarok Build-big-red-durbans-jpg
    Its been everywhere from the snow to the beach over the years I've owned it, been absolutely awesome. Will be in the family for a quite a while longer. (5years old last month and only 37000km)
    Sharkie's TSI Amarok Build-big-red-thredbo-jpgSharkie's TSI Amarok Build-big-red-nelson-bay-jpg
    Soon will (finally) get an upgraded exhaust.
