The red tab is a locking tab so that the plug cannot come undone by knocking it / vibration etc. So the red tab should slide out and then that will give you access to push another tab that will be hiding behind it to release the plug.
Thanks for that - I had tried to slide that red tab back - firstly with fingers, then gingerly with pliers. As it would't budge, I feared damaging it. I guess its clogged up with all matter of old desert mud and grit, which I did attack (unsuccessfully) with WD40. I shall return to the offending plug with renewed vigour!
This is the plug here. Having a look at the photos showing it from different angles should help you out. Photos of the plug
The red locking tab slides back a few mm and then you can press the black tab which should release the plug.
