Results 1 to 6 of 6
Thread: Outback armour suspension
    Oct 2017
    Have outback armour with HD springs and 10 mm spacer. Bull bar on front . The top of the tyres are tilting slightly to engine bay and need to rectify. I have 560 mm from wheel centre to under guard which seems to be in the correct range . How should I rectify this so front wheels are straight. Should I remove the 10 mm spacer?
    Pacific Paradise QLD
    Quote Originally Posted by Skullcrusher View Post
    Get a wheel alignment done seems a sensible idea
    Feb 2019
    Gold Coast, QLD
    Upper control arm... either Blackhawk or caloffroad. I personally run caloffroad.
    Oct 2017
    Thx . I will start with cheapest solution first Booked in wheel alignment this morning . Will let you know the outcome .
    Feb 2019
    Gold Coast, QLD
    The wheel alignment should get it close... the upper control arms will adjust castor closer to OEM which makes the wheel alignment easier.
    I did wheel alignment after my lift had settled and it fixed most of the alignment issues.
    Oct 2017
    . Wheel alignment got it back where it should be . The tyres look straight now from front on . The tyres were facing outward 25 mm from where they are now . Thanks for all your help
