the cherokee is a unibody IFS front Solid rear so no body spacers there mate, a good set of coils up front and an add a leaf or a extended shackle at the back and some longer travel shocks will give you the lift you need, and yes when i get my amorok i will be lifting the sucker a set of 31's all should be good then the yota mob will have something to think about
So you have done a suspension lift, not a body lift. You can lift a suspension setup as far as it will mechanically still function, hell, the Amarok could be lifted by around 120mm in the rear and 75mm at the front, but I'm not willing to put a figure on the life of the 4 front CV joints lasting any more that 20,000kms at that angle, especially if the vehicle sees a slightly rough road. Hence why we have stuck to 25mm, this will give a very good service life for the CVs.
No if arb have put the research in he wont be full of it, i did see a photo of an amorok with an ARB bull bar somewhere and that would have HD front springs to cope with the weight of the bar + winch and accessories
Seikel Amarok Extreme
Nuff said.
The Snowareg isn't bad either.
Driftn'
Now that's what I'm talkin' about!!!
- You may not post replies
- You may not edit your posts
Forum Rules
