Found the answer I was looking for, a wrecker on eBay was kind enough to take some measurements for me.
For the record it's 49 spline with diameter of 38.5mm. Which is the same as the output of the Touareg Aisin 8 speed.
Hi guys,
Looking at the possibility of swapping a manual transfer case with low range, onto an auto gearbox. Does anyone have access to a low range transfer case and could tell me the input shaft diameter and spline count please?
Thanks!
hey mate
how do you intend on going about this project?
Stage 2 Manual Polo GTI 6C, Stage 1 Amarok V6 x2, Mk1 Golf 1.8t 20v swapped
Am considering using a part-time Amarok transfer case in a 7P Touareg, since the factory 4Xmotion model is so rare.
ah ok i thought you were trying to put low range in an auto amarok...all good.
