Originally Posted by
lloydus67
265x65R17 is only 10mm wider than standard, I’m not certain but I believe factory rims are plus 35mm so plus 30 will bring your tyre and wheel 5mm further away from the chassis making a wider footprint. It will easily fit without any lift. If you have the standard bumper and not a bullbar, it may very slightly rubber at the front of the wheel arch on full uptravel of suspension when 4wdriving, but not so much as to cause an issue, more that you could see a mark on the plastic inner arch.
