Hi,
Thanks for the reply.
I was able to change the vehicle graphic to the Amarok, so thanks for that.
When I go to vehicle functions in OBD11 for the multimedia control unit, Bit 19 for RVC Low is set to disabled, but ODB11 won't allow me to change it, it keeps saying "function not available". I also checked for VPS in the BAP section and that is also set for disabled. Not sure what to do next.
Byte 19 coding has a bit for reverse camera (bit 4). Ensure that's ticked (RVC low).
If it is, then you need to go to adaptation channels, under 'Vehicle Functions BAP' and search for 'VPS'. Set that to disabled.
For the vehicle depiction, that is controlled by the first 3 bytes of coding.
For Amarok, change it to 061807. Probably set to Tiguan which would be 021306
Example:
02130600FF00000011510001000828001F0100C60020010003 this is from a Tiguan
Change to
06180700FF00000011510001000828001F0100C60020010003
