Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: DPF questions
  1. #21
    Jun 2021
    In an attempt to crack Enigma 2.0 (without directly talking to the programming Engineers), thought I would share my DPF observations from research & monitoring the VAGDPF app.
    It would be great if any others could share their understanding / observations to compare & confirm DPF function.
    1. DPF active regen appears to enable via soot mass calculated value 30-32g.
    2. Requires min 20km continuous driving to complete cycle. (Open road obviously better)
    3. Once the DPF regen is complete: soot calculated 4-5g soot measured 0-1g
    4. mg/km value – referenced to the soot mass calculated value.
    5. Soot mass measured utilizes sensors: dpf differential pressure, pre-dpf EGT, MAF.
    6. Soot mass calculated: EGT & Lambda sensor
    7. If soot mass measured is greater than calculated it will override the soot mass calculated (update the value) & enable a regen.
    8. When driving if EGT > 350C soot mass measured will maintain value or go down as EGT increases (passive burn) however soot mass calculated continues to increase (+ve mg/km value).
    9. Short trips or cold engine driving will increase soot approx. x4.
    10. 35g > soot < 40g you get your DPF light. (Go for a scenic drive).
    11. 40g > soot < 60g you get your glow plug / MIL. (Hope you have a quality scan tool)
    12. > 60g (Damn $$$$)
    Other DPF enable pre req's
    - 90C Temp
    - > 1/4 tank fuel
    - > 60km/hr
    Hopefully this helps others if having issues.
  2. #22
    Quote Originally Posted by GreyWolf View Post
    Hi Lucas_R
    Thanks for the update. I think I might trial the app as well. Out of curiosity what is your average mg/km when driving? (negating variation with load/condition). It appears any value > 350C Exh temp is in passive burn state.
    It would be great for the other 1500+ views if anyone else can share some data to compare & baseline.
    Sorry mate I haven’t looked at the data closely enough to know.
    All I really use the app for is to not only keep track of regens, but also to make sure the regens occur after the same/similar distance travelled each time to keep an eye on the general health of the engine (a boost leak or fuelling issue will fill the DPF up much more quickly).
  3. #23
    Jun 2021
    I agree,
    It is a great monitoring tool for the price. I use it the same way to record baseline & determine if there are any abnormalities presenting themselves or contributors to increased soot loading.
    I imagine as the DPF ages & accumulates ash (from burnt off soot), it will obviously reduce in volume which will increase regen frequency. I suspect this is also factored into the regen calc.
    If anyone can share or knows of
    - current ash value for your driven km's
    - the max ash limit for DPF?
    This may help to determine an average suspected life of the DPF.
  4. #24
    Jun 2021
    Something else that may be useful for others.
    - Using a phone screen recorder function / app to archive/capture the regen for future comparisons or troubleshooting.
    I have noticed variations in the soot mass measured value utilising the phone screen capture function. One prior to the engine being turned off. Then on the very next engine start-up.
    Any one else seen this or other abnormalities in monitoring?
