Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Brake controller
  1. #21
    Jan 2019
    "All your connections for the 7 pin"... There's only 2 connections.
    1) The brake sense between euro plug and 7pin - Vehicle doesnt detect this in its electrical system. Signal only sent to controller when trailer brake lights actuated, vehicle just thinks its part of trailer/trailer brake lights.
    2) Pretty sure the blue electric brake wire from controller went to an empty 7pin brake pin - hence no connection to cars electrics, just the controller.
    Note: I have a 13pin euro and genuine vw towbar/wiring. From the Euro plug I have a VW supplied 13 pin to 7pin adapter cable.
    Note: I originally had issues with the vehicle displaying an electrical fault (globe out) warning whenever I connected a trailer - VW blamed low voltage LED globes and wouldn't help and said to change trailer lights to non-led. Ended up making up an LED load box an plugged the 7 pin adapter into it with a 7 pin out of it - VW weren't happy with that idea but working fine for years now with no more faults. New 2019 models still cant handle trailers with LED lights...
  2. #22
    Pacific Paradise QLD
    Quote Originally Posted by wetaline2 View Post
    The blue wire goes from controller to Pin 5 ALWAYS
    Yes you only need the red from Brakelightsas you say I usually got it from a brakelight wire in the cab but would be hesitant on a VW.
    Shame you need so many connections Always gives more things to go wrong doesnt it,
