Auto headlights
Hi fellow rockers.
My issue I suspect is not necessarily confined to Amarok.
Mine is a MY14 Highline with Light & Vision and auto headlights. They stopped working some time ago with the switch on 'auto' and I have to turn the switch on manually to activate the headlights.
Dealer techie has tested light sensor and all is good with in range values and has him scratching his head, all at my expense as I'm out of warranty. Leaving home' works but 'coming home' stopped working around the same time even though it is activated.
I have LED DRLs in BB which are active from #15 terminal plus park circuit so that the taillights are on during the day. A trigger wire goes to each headlight low beam to turn off the DRLs when the headlights are on. I thought that a feed back may have been the issue so installed diodes to no avail.
Any ideas? I'm guessing a BCM fault but no faults come up when I do a scan using Ross Tech.
"You don't know what you don't know"
Cheers dave
- You may not post replies
- You may not edit your posts
Forum Rules
