Results 31 to 34 of 34
Thread: Amarok Wheels and Tyres
  1. #31
    Jan 2022
    WA
    Quote Originally Posted by I_Am@rok View Post
    Hi all,
    After much debating I have finally chose to go with some Falken Wildpeak AT/3’s for my 2019 V6 Highline. I have a question for the learned amongst this group however.
    The Highline came with Bridgestone Duellers from the factory (255/60R/1.
    I am fitting the Falkens at a slightly different size - 265/60R/18.
    My question is, is there any kind of speedo calibration required for fitting the new size tyres?
    Any advice and/or pointers you can provide will be appreciated
    I have run these for 80k km so far and just need replacing now. All factory speedo's read under to avoid liability from manufacturer. With these tyres, I can drive 113km/hr and camera doesn't flash even in averaging areas. GPS is the best test as the speedo difference is exponential. Slower speeds, it's closer, faster and its further out.
  2. #32
    May 2022
    eastern shore of Te Whanganui a Tara
    VW speedos run 10% fast so when it says 100kmh you will be doing 90kmh.
    I fitted 10% greater diameter tyres to my 2014 to counter that difference.
  3. #33
    Aug 2024
    Vicco
    Gday everyone. Looking to put some 33" or 35" tyres on my 2015 4cyl rok. I have HD shocks and a 50mm HD coil in the front. Any recs/advice for some larger tyres? Cheers.
  4. #34
    Jun 2020
    QLD
    If you don’t want to damage your front cv’s don’t do a suspension lift where the under guard to centre of wheel measurement is greater than 565mm unless you are going to install a diff drop. Some people still have issues even after the diff drop.
