Results 1 to 8 of 8
Thread: Amarok Temp Gauge
    Mar 2018
    MACKAY
    Amarok Temp Gauge
    Hi All,
    I have a 2013 Amarok Highline which only came with an engine temp warning light and no gauge. Recently the warning light has been coming on with no obvious signs of overheating and the fluid level seems fine. I was wondering if anyone had fitted a proper temp gauge and where they wired/connected it in?
    Stu.
    Jun 2013
    Qld
    I used an obdII device connected to my mobile to check live temperature.
    Was pretty good and easy to set up.
    Sent from my SM-G965F using Tapatalk
    Mar 2018
    MACKAY
    That looks good. Will check it out. Saves running wires etc. Thanks.
    Jun 2013
    Qld
    Don't go for really cheap one. As you don't want to damage ECU.
    Dec 2008
    Sydney/Canberra
    Have the cooling system pressure tested, and check for sludge in the EGR cooler.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2016
    Berwick, Victoria
    Quote Originally Posted by jeromeo View Post
    You won't damage the ECU. The worst you can do is lose connectivity with the OBDII port.
    VWAmarok
    Jun 2013
    Qld
    Quote Originally Posted by VWAmarok View Post
    VWAmarok
    Thanks.
    good to know.
    Mar 2019
    Hi Stu
    What did you end up doing in the end?
    Also, I wonder if the 2014-on speedo could be retro-fitted to the non-temp gauge Amaroks?
