Results 1 to 3 of 3
Thread: Amarok Side Step Replacement Treads
    Mar 2017
    Buderim QLD
    Hi All
    I have just bought a V6 Amarok and have fitted what I believed to be genuine side steps (which I sourced privately). The step treads are a hard plastic and are quite slippery when wet. I was wanting to replace these with rubber treads for safety reasons. (I don't want the wife or kids having an accident slipping off them.) Anyone know if these are a part that can be bought? I haven't had any luck checking VW part sites.
    Thanks in advance for your replies.
    Bernie
    Nov 2007
    All the OEM steps use the same plastic tread bits. I have not seen otherwise. You will have to try aftermarket which may mean you have to sell yours.
    I use more mine a lot and haven’t noticd them to be slippery even when wet.
    Mar 2017
    Buderim QLD
    Side Steps
    Thanks for your reply. I have since checked quite a few Amaro's with side steps and they are all the same as mine ,so it appears I did find genuine ones after all. Good to know you have had no problems with slips with yours.
    Cheers.
    Bernie
