Results 1 to 2 of 2
Thread: Amarok roof racks. Installation is as easy as it looks.
    Sep 2021
    Lansvale NSW
    Amarok roof racks. Installation is as easy as it looks.-img_6067-jpg
    M21 Trendline
    Amarok roof racks. Installation is as easy as it looks.-img_6068-jpg
    Using either the key or a regular flat tip screwdriver, turn the locking screw 900
    Amarok roof racks. Installation is as easy as it looks.-img_6069-jpg
    and pop the tab out
    Amarok roof racks. Installation is as easy as it looks.-img_6070-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6072-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6073-jpg
    Locate the securing bolts.
    Amarok roof racks. Installation is as easy as it looks.-img_6074-jpg
    Hex key required to remove the bolts pre-installed in the roof track
    Amarok roof racks. Installation is as easy as it looks.-img_6076-jpg
    Remove factory bolt with hex key and insert the securing bolt into the thread.
    Washer goes below nut, rubber side down.
    Amarok roof racks. Installation is as easy as it looks.-img_6077-jpg
    A ring spanner applied to top of hex key reduces the risk of scratching.
    Amarok roof racks. Installation is as easy as it looks.-img_6078-jpg
    Bolt goes in about 35mm
    Amarok roof racks. Installation is as easy as it looks.-img_6080-jpg
    Remove the lock
    Amarok roof racks. Installation is as easy as it looks.-img_6081-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6082-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6083-jpg
    tighten bolt
    Amarok roof racks. Installation is as easy as it looks.-img_6084-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6087-jpg
    Open doors to get access, even if you do have running boards
    Amarok roof racks. Installation is as easy as it looks.-img_6088-jpg
    Undo the ratchet bolts at least 5 full turns.
    Amarok roof racks. Installation is as easy as it looks.-img_6089-jpg
    This plastic insert slots into the rack
    Amarok roof racks. Installation is as easy as it looks.-img_6090-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6092-jpg
    Plastic insert goes in here...
    Amarok roof racks. Installation is as easy as it looks.-img_6094-jpg
    and clicks into place.
    Amarok roof racks. Installation is as easy as it looks.-img_6095-jpg
    Fit the rubber boots
    Amarok roof racks. Installation is as easy as it looks.-img_6096-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6099-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6102-jpg
    Racks go on with blunt edge leading. If there's not enough thread to bolt onto, raise the threaded rod until you have about 10mm above mount.
    Those Pro Racks are the best. No noise, no turbulence, quick release and something like $140 delivered. That's about a $350 saving on Rhino and Thule and I don't think any of their products can match the thin, aerodynamic profile of these, though the Rhino's make a wing version now that comes close but they are still $400 -500 for a set.
    I had some Rhino/Thule track mounted bars mounted on the rear but it was impossible to get something in an 85mm lift for that. 120mm is the standard mount. There was some interference with the canopy spoiler for a while, but sorted that out by moving racks forward. Even at urban speeds, the buffeting was noticeable.
    Sep 2021
    Lansvale NSW
    Amarok roof racks. Installation is as easy as it looks.-img_6103-jpg
    2/3 thread above nut, 1/3 below
    Amarok roof racks. Installation is as easy as it looks.-img_6104-jpg
    With about 8-10mm thread above mount, fit securing nuts.
    Amarok roof racks. Installation is as easy as it looks.-img_6108-jpg
    Amarok roof racks. Installation is as easy as it looks.-img_6110-jpg
    Fit nut
    Amarok roof racks. Installation is as easy as it looks.-img_6115-jpg
    Tighten with plastic spanner provided.
    Amarok roof racks. Installation is as easy as it looks.-img_6119-jpg
    Set the racks so that you have approx the same number of notches on either side, then tighten ratchet with hex key.
    Amarok roof racks. Installation is as easy as it looks.-img_6120-jpg
    Fit the locks. If locks don't fit, remove the blue plastic spanners that came with the kit.
