Alas, no .... the switch activates the rear foglight. No wiring exists for the front I'm afraid.
It is easy enough, however to fit front fog lights and wire it up.
You will need:
1) (and I'm assuming you have auto headlights) Car Auto Headlight Head Light Switch & Sensor For VW Golf 5 6 MK6 MK5 5ND941431B 883331013877 | eBay just check the plug on the back is the same shape as the stock Amarok switch.
2) Full Set Fog Light Spot Driving Lamp KIT For Volkswagen Amarok 2H Ser 2 16~On | eBay
Instead of wiring to the switch provided in the kit, wire to the open pin on the headlight switch for a proper OEM look.
