Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Amarok Engine Light
    Quote Originally Posted by xDevo View Post
    The saga ends, hopefully. I took the cooler out to find it very clogged and after nearly 2 cans of break cleaner the thing is pretty well clean except for the part that curves around which I can't get to with my metal poke rod. I'm hoping it has been cleared out enough. Once I put the cooler back on I ran about half a can of luqui moly through the intake as well to get any last bits. Yet to take it for a long drive but if the light comes back it's safe to say I'm replacing the entire bloody thing
    Good work. Im sure what you have done will sort it. Just FYI for next time, I found carby cleaner to be much more effective than brake cleaner to dissolve and break down the sooty carbon mess that builds up. I tried various products that I had in my garage (metho, turps, petrol, brake cleaner etc) and the carby cleaner was the best by far.
    But at the end of the day, regardless of what product you used - its clean now.
    Jan 2022
    WA
    If it comes back on, do your self a favour, bypass it and get a tune to turn the EGR off and who doesn't more power?
