Results 1 to 10 of 13
Thread: Amarok charging voltage?
    Jan 2016
    Wentworth Falls
    Question Amarok charging voltage?
    Hi,
    Does the 2015 Amarok charge at 14.2V or does it drop the charging voltage after the first few minutes?
    I'm wondering if I need to fit a DC-Dc charger for the auxiliary battery?
    Cheers,
    Tony
    Quote Originally Posted by Blugnomad View Post
    Hi,
    Cheers,
    Tony
    The voltage will likely drop as the current output falls. So highest voltage just after engine start.
    I would have thought the alternator would be plenty able to charge a second battery. Especially if you don't run it flat first.
    Jan 2016
    Wentworth Falls
    Hi Gavin,
    A lot of new vehicles drop to 13.2V to save fuel. Some don't, they stay at 14.0 to 14.2V, I'm wondering which group the Amarok is in.
    Tony
    Hi Gavin,
    Tony
    You better link me up, I haven't heard this before.
    Jan 2016
    Wentworth Falls
    Hi Gavin,
    All the 4wd Toyotas ( google diode mod), Nissans (green wire mod), practically anything since about 2010 where the ECM controls the alternator.
    Improves the emissions and the advertised fuel consumption and the sales of battery boosters for caravans and auxilary car batteries.
    Cheers,
    Tony
    Hi Gavin,
    Cheers,
    Tony
    Never heard of this on a VW but I'll wait to be corrected.
    Adelaide hills, SA
    Hi,
    Cheers,
    Tony
    Just connect the voltmeter to the fully charged battery (with the bonnet up), start the engine and observe the voltage.
    Jan 2016
    Wentworth Falls
    Since my previous posts I've done a long enough trip to see that the voltage settles to about 13.8V. Not enough to fully charge an auxiliary battery. Now I need to decide what boost is necessary, as it's almost enough.
    Cheers,
    Tony
    Adelaide hills, SA
    Why you don't use 12V to 12V charger? It would greatly extend the life of the second battery. Projects and RedArc are great and even allows you to connect a solar panel.
    Jan 2016
    Wentworth Falls
    That's the next step, I've got a low powered DC-DC but it appears I need at least a 20A.
    As Abba sang. "Money, money, money...."
