I use Hengst, Mahle, Mann filters at work. Same spec as VW. No idea how fine they filter. I am always reluctant to use any other filters on VWs.
Does anyone know the micron rating & efficiency of the OEM Oil filter in the V6 3.0L TDI engine?
Do you use a particular aftermarket oil filter? Reason?
Which alternative oil to use? spec 507.00?
Thanks Greywolf
Hi h100vw,
Thanks for the info. Is the majority of engine oil used 0W-30 507.00 spec?
I'm sure you'll find it is 5w30. I get the part number from partslink and search Google or an oil manufacturers website
