Page 56 of 65 FirstFirst ... 6465455565758 ... LastLast
Results 551 to 560 of 644
Thread: You know you drive a Mk1 when.....
  1. #551
    May 2012
    Victoria, north melbs
    When you slam too hard on the brake and you heel disappears through the floorpan!
    Slight bit of welding this weekend!
  2. #552
    Nov 2008
    Canberra
    Pull into the drive again, notice a little steem coming from the bonnet, pop the hood find a tiny leak of coolant spraying straight up into the air from the middle bottom water pump hose. Doh.. new coolant hoses are in order! Probably got a blockage somewhere..
  3. #553
    Dec 2009
    Melb, VIC
    When the car is in the garage and the whole house smells like fuel!
  4. #554
    Feb 2010
    Queensland
    when you get home in a tow truck
  5. #555
    Mar 2011
    Bunvegas, Western Australia
    When you continuously, and unnoticeably drive around using only your low beams in your daily because they're the Golfs equivalents of high beams! (If you're lucky haha)
    1976 VW Golf "Swallowtail" - Rallye Red (long term resto)
    2009 Pirelli GTI - Stg3 killer
    2009 R36 Passat - Daily baller
    You take corners on three wheels, and V8's can't catch you.
  6. #556
    Sep 2009
    Mornington Peninsula, VIC
    When you drive it, you just cant help but grin!
  7. #557
    Gosford Central Coast NSW
    When you have to take one for a drive, because you feel depressed about cutting one up for parts
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  8. #558
    Mar 2010
    Bathurst, NSW
    You know you drive a MK1 when you rip the sump plug out of the sump on a bitumen back road cause the suspension is stuffed. At least the smell of engine oil on the exhaust saved the motor.
  9. #559
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by ByronRichesMk1 View Post
    Relay mod and 55/60w globes help this
    <space for rent>
  10. #560
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by GRN_VAGN View Post
    I went to 90/100W globes - they are steel and glass - no melting going to happen there!
