you know you drive a mk1 when you get compliments from homeless guys and security guards
When you indicate and the brake, tail lamp and reverse light all flash at the same time.
you know you drive a mk1 when you feel like your spine is about collapse, after driving for 5 minutes, when you accidentally set your front shocks (koni yellow) to the firmest setting
You know when you drive a GLD when you have to "shake n bake" to overtake
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
when you've sold your MK1, watched it taken away on the back of a truck and contact the new owner every day to see if it arrived safely.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
You take corners on three wheels, and V8's can't catch you.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
When your stuck in traffic and the truck next to you side exit exhaust directs straight into your passenger window
Radiators are over rated
You pull into your drive way after work to grab things and pick up some friends just as you park the stereo turns off and won't turn on again..
When going from a 4x4 daily to finally driving the mk1 for the first since buying it and fixing it.
little tin can on wheels... coilovers and leaking exhaust.
Seems i need to do more work to it
<space for rent>
