Page 33 of 35 FirstFirst ... 233132333435 LastLast
Results 321 to 330 of 347
Thread: YES!!! I bought a mk1
  1. #321
    Jun 2007
    Eastern Suburbs Melbourne
    I think you've got something wrong with the Kjet. Sounds like a warm up reg issue to me. hence you can only start it when it's cold, but when it's warm it doesn't work.
    Try and get in contact with Tim. He might be able to help you out.
    EDIT: or search around in the mk 1 section, there are plenty of post's with links about Kjet troubleshooting and so on and so forth.
    check the alternator with a multimeter for starters (across the batt, whilst car is running). if the starter still starts it, I wouldn't think there's a problem with it, unless it's super super super slow to crank it over.
    i like volkswagens
  2. #322
    Sep 2006
    Australia?
    Cheers Jarred will try and get onto Tim tonight, however its weird when I start my car and don't leave it to warm up as long as it does sometimes and drive off its fine
  3. #323
    Jun 2007
    Yea, I'm still going to go with Kjet issue. Does it stall once you start driving and then it gets warm (say if you're sitting in traffic??)
    i like volkswagens
  4. #324
    Sep 2006
    Australia?
    Nope, it happened a few times in the period of about 2 months and after each time it was fine
    If I get in the car and drive and not let the car idle too much its fine, no stalling in traffic nothing
    It happened again friday this time my dad took it up to the autoelectricians and he cant book it in till thursday which is what I did, but just trying to think what it could be. It won't even kick now so the battery looks like its drained. We measured the battery volts yesterday at 11.56V, shouldn't it be around 13V? and this was at the battery itself.
  5. #325
    Jun 2007
    it's a 12V batt, so it should be about 12.5V without anything on. When the cars running, it should be around 13.5-14V, with nothing (lights etc) on
    Have a look in my diesel thread, there's abit of info in there about finding shorts and other battery related things. I'll link you in 2 secs.
    http://www.vwwatercooled.org.au/newf...=24016&page=32
    look through the last couple of pages, hopefully that'll be a start there.
    i like volkswagens
  6. #326
    Sep 2006
    Australia?
    Cheers mate having a looksie now
    Will have to update this thread with pics seriously its pic deprieved lol.
  7. #327
    Sep 2006
    Australia?
    So just thought I would update this thread, but just managed to get the car to the autoelectricians yesterday. After charging the battery for 2 hours took the charger off and tried to kick start it, almost it was idling and then died. Waited twenty mins with the charger on the car this time as I started the car, kept the car revving to get it up there but it worked, WTF is wrong no idea
  8. #328
    Jul 2005
    Newcastle, NSW
    I had a similar thing, not necessarily your issue - but I had a dodgey lead connection to the fuel cut off solenoid from the ignition. I changed the lead and the ignition switch and the issue has not returned.
    Sounds like it is starving of fuel.
  9. #329
    Sep 2006
    Australia?
    Quote Originally Posted by mikinoz View Post
    Hmm interesting I also thought about that but I only just replaced the fuel pump in March.
    Anyway I got a call from the auto electrician, and well I have been ****ed! there was a cable from the alternator to the battery that was frayed that needed replacing which was cool and then this:
    AE"Steve how old is your battery mate?"
    Me"Only just brand new 6 months I got it in January when the car was blueslipped"
    AE"I checked the date and its from the 08/04"
    Me"Phuk off?"
    AE"Yeah you have been jipped its losing a full volt when you turn your lights on!"
    Me"Hmm well thanks mate"
    So looks like I will be knocking on someones door with a bat anyone care to join me? We can have a cruise while we are at it?
  10. #330
    Jul 2005
    Newcastle, NSW
    I always buy my batteries from NRMA now. They fit it, have a replacement on the street side if it fails under warranty and they are REALLY POWERFUL. (albeit a bit more expensive) Your story sucks - sorry to hear.
