welll.............
check the gap between the front guard and the door,if the top is higher, undoo the top bolt of the door bracket and move the door up, or vise versa, you might fix the door level but the guard gap might be crooked
if the gap is good all the way through, get a nice soft block of wood wrap it in a rag and a jack, open the door and jack the bottom up A LITTLE BIT!!!
then check the gap little by little........
last idea sounds dodgy..... but it works
dom
