Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 121 to 130 of 141
Thread: Yellow 4 Door Project...
  1. #121
    Mar 2019
    Camberra & New South Wales
    Quote Originally Posted by genebaby View Post
    Cool, always something happening. Good luck with the heater, after today you know you need it.
    Not sure what's the best way to go with the engine, maybe petrol if you're going to touch it anyway?
    That is what I was thinking. But then the question is what do I do?
    1) 1.8L 8V
    2) 2.0L 8V
    3) 1.8T 20V
    4) 2.0T(Mk5 GTi motor)
    The possibilities are endless. Depends on how much I can afford at the time of making the decision.
  2. #122
    May 2020
    Canberra
    Will the Mk5 motor be more hassle to engineer?
    Otherwise most powerful NA that will be easiest to get in.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
  3. #123
    Mar 2019
    The Mk5 motor I will need to modify the dash as the dash helps run the motor and make a fair few mods for the front suspension and brakes etc.
    But it is doable. And the Mk5 motor is turbo charged which could do with an APR mapping or stage upgrade.
  4. #124
    May 2020
    Canberra
    The turbo would be awesome if you can swing am that but I'd be happy with a better NA engine and enjoy it.
  5. #125
    Mar 2019
    True that. So I’m contemplating what to do. I was even thinking a 1.9TDi or 2.0TDi.
  6. #126
    Mar 2019
    And then do a stand alone mapping system to help with low end torque. Yellow 4 Door Project...
  7. #127
    May 2020
    Canberra
    You've got some options, that's for sure.
    I guess what's available will help you decide.
  8. #128
    Mar 2019
    Sure do have some options. For now all I want to do is get her on the road and enjoy her. It’s been a process and a half to get to this point with all sorts of stuf going on.
    But I’m making it happen and just staying focused on the basics.
  9. #129
    May 2020
    Canberra
    Yeah, get her on the road and go from there.
  10. #130
    Mar 2019
    Where are you located? Sounds like you might be close to the ACT?
