I had the same issue and had to reorder pads for ones that were thinner. they looked identical and I thought my calliper wasn't all the way input I eventually found it was pad thickness that was the problem...
So, I’m having problems fitting the brakes. Apparently early ‘79 and late ‘79 have different thickness rotors and from the details I found on my car I have the right rotor thickness. But the pads don’t fit.
Here are a few pictures of the old and new pads which according to size is the exact same.
Anyone with info or help on this issue, please share I really can’t figure this out. My last resort is, overhaul kits for the callipers and just pulling it apart, cleaning it and then fresh seals etc.
Went and double checked with the shop I bought from and there are two pads listed with the exact same thickness.
Worst case scenario, I buy overhaul kits for the callipers and maybe do the same and search for exact pad but slightly thinner.
I just machined off the extra thickness on a set of bike pads...
The material is the same on both types, just the thickness that’s different.
'90 Mk I Cabriolet 1.8L - My toy... err... Daily driver...- Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
'99 Mk IV Bora V5<-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
'05 Volvo T5 S60 - 2.5L Turbo AWDReplaced with '09 Ford LV Focus Sedan <-- Used by the kids
'07 Eos 2.0 TFSI - Project Eos...
You should upgrade to the MK1 GTI front brakes. Ventilated disks and the pads are twice the size. Gives you much better stopping power.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Late model cabriolets (ie clipper kit ones) came with gti brakes.
From memory, You just need the callipers and then get new disks + pads.
Been away from the car for a short period due to work and other commitments.
Brief catch up on everything:
Put the old rotors and pads back in the front so I can get her on her wheels.
I have brackets being laser cut for the LED headlights. (Should have it on monday)
I have the air guides for the radiator being cut as well.(should have it on monday)
New water pump installed, and prepping new radiator for fitment during the next week. Gotta fabricate brackets to make the old fan shroud fit as the new radiator is GTi(will look for GTi shroud and fan a bit later)
Gotta get the mock up made today for the new expansion tank I have as well, so I can get that laser cut during the week.
And I realised that the timing belt tensioner I originally bought was to narrow, but luckily Repco could help when I was able to find the genuine part number. Also fitting that today and getting all the timing stuff sorted.
Will post pictures during the week with the lights and the air guides for the radiator etc.
Looking forward to the pics.
MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
MY19 AW Polo - Comfortline - DAP
New Timing belt
New Timing belt tensioner
Timing adjusted to have near perfect TDC
New Water Pump
New water pump/alternator belt
New front engine mount bush
Fuel pump timing set
Still to do:
New coolant hoses
Rubber grommets/feet for new radiator
Expansion tank bracket design
New thermostat
New coolant
Install new brackets for LED lights and then work on light placement
And I had my supervisor with me at all times to make sure I do things right and not miss anything.
