Results 1 to 9 of 9
Thread: yay
    May 2006
    Maryborough Vic
    Talking yay
    got all my engine parts back from the
    machinest on sat yay!! he finally finished
    putting the big valves in they look sooo hot
    they almost touch. and also got spec's on
    the cam cause it was pitted so had it reground
    it's got .366 thou lift he called it a 340a grind
    i was told it was a scat c35 air cooled grind ?
    will have pics soon misses broke camera have
    to use phone.
    should sound hot and go even harder!!!
    The C35 scat grind has
    .381" lift @ the lobe
    285 degree's advertised duration
    246 degree's duration @ 0.050" (unknown lobe centre!)
    That's a mean cam duration wise (3800rpm+ start of power!) for a golf, but the lift is way off. I'd get your machinist to recheck it.
    It should have at least .440" to .450" lift. with 108 - 110 degree's lobe centre.
    For interest, my 270 degree cam has .449" lift & 112 lobe centre.
    Check this page for a comparison & you'll see what I mean.
    http://techtonicstuning.com/cams.asp
    May 2006
    Maryborough Vic
    Talking
    got pics on phone tonight
    not sure on all cam specs . it idled at about 1000 to 1200 rpm
    it has less lift than standard cam but head was built to suit
    power starts at 3000 3500 rpm to about 7500 8000 rpm lots of
    fun!!!!
    Camden, Sydney
    Bang it in and see how ig goes.
    And nice work on the lilac
    Look's like your machinist does nice work!
    Smooth job on the port's.
    Pity you can't do any more valve relief work due to the head gasket bore size as this would make a huge difference!
    Sorry for questioning your cam spec's, but when you said it was a air cooled grind spec it was alittle bit weird.
    Remember with a aircooled engine you have ratio rocker arms to direct & increase movement onto the valve's, where as the golf cam is direct onto the valve.
    A C35 with .381" lift @ the lobe & 1.25 ratio rocker arms you will have 476" lift @ the valve.
    I'd still double check though.
    May 2006
    Maryborough Vic
    Talking
    my mate made the cam at a big adelade
    mach shop and thats the cam profile he
    used ( he had the golf for 18 years ) but
    when i had it redone cause of pitting the
    machinest couldn't identify it so he made a
    profile of it (and didn't charge me cause want
    keep the profile) ex and in have .366 lift and
    both have 245 of duration . its not the norm
    but it went very well till head gave out, hence
    the rebuild. thanks for the link
    Allens Rivulet, Tasmania
    purple. briiiiight
    May 2006
    Maryborough Vic
    Angry
    it been over a month and i've done
    bugger all no time everthing is outlaws
    shed which has no power. take week off
    to get it back on the road next month
    put crank and pistons though
    got all the tools i could ever need
    just no dam shed. eng looking bright though.
