yup! dished black mk3 steelies look good to me! slam it on whitewalls and it'll look mint mate
They are just stock Mk3 steelies with the plastic trim?
I`d go wider, b ut thats me
Rear spacers needed. Look good Costa!
I had a set of those on my mk1 and they do look good. But mine were the original silver. I'm not a fan of black steel wheels.
mk2 GTi 16v
Corrado G60
Black steelies are ace. Are they 14 or 15"?
They are 14x6 ET45
Like evorobin said. You'll need at least 5mm spacers.
I've had several set's with 185/60R 14 & always had to put a 5mm spacer on the rear only to clear the coil spring. Fronts are fine.
i had these on my mk1 and didnt need a spacer
and they look hot
78 Mk1 Golf
62 beetle still 6 volts
