Results 1 to 10 of 16
Thread: Wiring for early GTI system
    Camden, Sydney
    So I just got this engine from an early GLI cabrio and it has no wiring loom with it. It does not need an ECU and has minimal connections needed, was just hoping one of you guys can tell me how to hook it up.
    May end up junking the full electronic system from the jetta and using this one.
    syncro Guest
    Yeh, I used to make looms for K-jet.
    Make sure that you get the correct fuel pump relay.
    Camden, Sydney
    I`ve got a relay, do you wanna make me a loom?
    Jul 2005
    I have a complete early K Jet loom from my Scirocco which I would swap for a good un butched LS or GLS loom.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Camden, Sydney
    I`m up for that swop, I`ve got a few looms. I`ll check tomorrow how straight they are.
    Although you have just reminded me that I should have an early Audi 80 loom, which is prob the same.
    Golfwise Guest
    Loon why don't you run the Jetta on early no computer k jet like early mk2 GTIs.Mine is UK import with no ecu at all.Purrs like a kitten
    Camden, Sydney
    Yeah didn`t think of that till I got home with this motor, but its probably the shot, as its simple and the airbox is smaller.
    It still needs a couple of wires though doesnt it?
    I want to get her going by the weekend if possible for the cruise.
    Golfwise Guest
    only electronic ignition.
    Use early type fuel metering unit (Saab ones are a go) without the need for any electronic adjustment, and a simple vac adv type dist.
    Camden, Sydney
    Ive got the original cabrio metering system is that better than a saab one? And literally no other wires!!!
    Golfwise Guest
    assuming the fuel system is already wired up.
    Well I assumed it was
Similar Threads
  1. Jetta Audio system
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 04-10-2006, 07:49 PM
  2. Diesel cooling system
    By smithy010 in forum Diesels
    Last Post: 21-07-2006, 01:17 AM
  3. Wiring diagram?
    By 82cab in forum Mk2 Golf & Jetta
    Last Post: 16-12-2005, 05:45 PM
  4. Wiring Diagram
    By el_foolio in forum Mk1 Golf
    Last Post: 11-11-2005, 09:56 AM
